Excel color cells with python
Hi there!
I’m trying to color some cells in excel by python.
I was watching this topic in order to undertand how to do it:
It works fine, but just with two rows and I don’t know why.
Here the script where you can see that works with two rows:
Here the create dictionary node:
 excelRow =IN[0]
 dictcolor = {}
 for e in excelRow:
           dictcolor[str(e)]= "192,192,192"
 OUT =dictcolor
And here Paint cells:
 import System
 from System import Array
 clr.AddReference('System.Drawing')
 import System.Drawing
 from System.Drawing import *
 clr.AddReferenceByName('Microsoft.Office.Interop.Excel, Version=11.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c' )
 from Microsoft.Office.Interop import Excel
 from System.Runtime.InteropServices import Marshal
 xlDirecDown = System.Enum.Parse(Excel.XlDirection, "xlDown")
 xlDirecRight = System.Enum.Parse(Excel.XlDirection, "xlToRight")
 class Lst_Xls():
 	def __init__(self, path, dictcolor):
 		self.dictcolor = dictcolor
 		self.lsta =[]
 		ex = Excel.ApplicationClass()
 		ex.Visible = True
 		lst_xls = []
 		workbook = ex.Workbooks.Open(path)
 		ws = workbook.Worksheets[1]
 		##get number of Rows ##
 		rowCountF = ws.Columns[1].End(xlDirecDown).Row
 		##get number of Coloun  ##
 		colCountF = ws.Rows[1].End(xlDirecRight).Column
 		self.fullrange = ws.Range[ws.Cells(1, 1), ws.Cells(rowCountF, colCountF)]
 		self.fullvalue = self.fullrange.Value2
 	def setRowColorbyDict(self):
 		for row in self.fullrange.Rows:
 			rangerow = row.Value2
 			firstvalue = rangerow.GetValue(1,1)
 			if firstvalue in self.dictcolor:
 				strRgb = dictcolor.get(firstvalue)
 				row.Interior.Color = eval("ColorTranslator.ToOle(Color.FromArgb(" + strRgb + "))")
 				self.lsta.append([firstvalue, strRgb])
 #dictionary to complete
 xlspath = IN[0]
 dictcolor =IN[1]
 obj_xl_lst = Lst_Xls(xlspath, dictcolor)
 obj_xl_lst.setRowColorbyDict()
 OUT = obj_xl_lst.lsta
Thks.
Manel
Please edit your code in right format. It is hard to read it.
Did you see my last post in that topic? I am not sure what your end goal is but maybe my final script will help?
Sorry Deniz.
Done it!
Manel
Hi Steve,
Yes, I did. But I didn’t want to control rows and columns, I’m interested in color some rows with specific names.
The thing is that I didn’t know why it works just with two rows.
Thks
Manel
Can you provide a screenshot of your full graph and of the excel file you are trying to color?
The section above reads the excel file and gets the count of rows and columns. Without seeing your data structure it is hard to say why its not working.
Finally I did it with you scripst because I couldn’t get a result with others options
Thks
Manel
