Okey, have you checket out the test files in the link? He is using the exact same script as I and he gets it to work… I understand what you mean and i see that this can be a problem, but i think its wierd that he make it work whit the same script.
What elements do you have in your slection when you hit run ? Because it looks like you might be selecting families that don’t only contain solids but also polycurves.
Hi, it’s not the topography that you should pick in my script you should select the elements that you want to excavate for, ie the bottom floor and structural foundations.
I tryed to cut it out first but it dont understand that it not should make a solid fill inside… And of what i understand by reading about my problem dynamo have no box for making a building pad whitout makit the script by myself?
i tried it but also it didn’t work in dynamo 2
i received this errors after selecting the floor and clicking run
i used your mail file #jostein_olsen
It says right in the script that you have to pick the topography:
The Spring.Collector.CurrentSelection node takes whatever geometry you have selected in Revit when you click run in Dynamo(floors etc.)
@jostein_olsen@jostein_olsen
i tried again with new copy from your .rvt & .dyn and modify the geometry scaling again i had the same 10 yellow nodes again
i am using Revit 2018.1 with last version from Dynamo
