Good morning to everybody.
I have the following problem, which is to create walls per face from the surface of a generic model.
1° The first thing I want to obtain is a wall that then allows me to edit the profile of this wall.
2° The second thing is that I require that the walls belong to a specific level, since each wall is born from a column at a certain level, but it happens that when assigning a level the element is moved out of phase from its original location.
Please, I will greatly appreciate your support.
FORMWORK_EXAMPLE.rvt (7.1 MB)
FORMWORK v.01.dyn (164.2 KB)
