hello. I want to use wall.by face . but error.
sorry for my bad english.
wall.dyn (5.8 KB)
it says one or more type mismatch.
I have uploaded dyn file.
@lastmonth There are a couple of things wrong in the graph. First, it will not work the Surface created using Geometry in Dynamo, and it has to be a Surface or Face selected from Revit, another thing is Location Line should have input as String which you can use it from Wall Location node. I have attached sample Dynamo file, give it a try and let me know if you have further question. (Please create one Surface in your Revit project file and select it using the Select it using Select Face node in my graph.)
WallByFace.dyn (23.1 KB)
thank you very much.
I understand . and I have test your file. It’ok.
but if I want to use surface created from dynamo… not a Surface or Face selected from Revit.
how to do …
No, you cannot use the Geometry created in Dynamo, it has to come from Revit only.
