Hi, everyone!
I have a routine created and tested in dynamo. However, when I use “Dynamo Player” to select the inputs, the result is “run completed with errors” and no result is generated.
Does anyone know the reason for this error?
PS: When I open Dynamo and select the inputs, it works perfectly
Hello @rbp1997 …could you share the dataset ?
Criar vigas.dyn (29.0 KB)
@sovitek ,
The routine basically creates a beam from a curve, between the columns, from a start point and an end point.
It is in Portuguese, but some translations follow:
“viga” = beam
“pilar” = column
“pavimento” = level
Hello…think player had a problem with selection points…but you can try this here instead…
VIGAS.dyn (36.3 KB)
That was exactly it! Thanks again!
