Hello I am trying split or cut the the element by the following script. I am also able to cut the geometry and cut lines are visible. The script runs well without a single warning. But the member is not getting separated from each other. If I select the member, it seems only one. So kindly request to help out in deleting or trim the cut elements from the main member.
I suspect that it has worked, but the Dynamo preview is showing the node output from both the cut and uncut geometry.
If you right click on the nodes, you should see ‘Preview’, if you uncheck this, the preview will only show the bit you want. You can also use a Watch3d node…
Hope that helps,
Mark
