Does anyone haven an idea how to solve this?
The elements (to be cut) and the elements (cutting) are both created from within Dynamo.
Maybe I dont have to use the unwrapping then? Or the command is wrong? the code Ive written so far is in the printscreen below:
The error means that the command is looking for a Revit element, but it looks like you are getting and feeding it geometrical parts or representations of elements. I would just make a simple graph and Python script that just does two single elements, the format it to make it work on lists.
Thanks, that would be the best I hope!
Do you know what python command should be used to cut geometrical parts?
As you say the command addcutsbetweensolids only works on revit elements.
