I am super new to Dynamo and want to write my windows in a json file. but when I connect my directory to stringify.Json, I get this error :
Warning: Data.StringifyJSON operation failed.
Error getting value from ‘WorksharingCentralGUID’ on ‘Autodesk.Revit.DB.Document’.
What does this mean? How can I correct this?
SeanP
August 3, 2022, 6:09pm
2
Do you have the most current version of the package installed?
Also, what version of Revit and Dynamo?
Seems to be working for me:
Hi Sean,
I only get this error for windows. Room and electrical fixtures seem to have no problem.
I am using Revit 2020 with Dynamo Core 2.3.0.5885 Dynamo Revit 2.3.0.7661
I believe you’re passing a Revit element instead of a string for the Level parameter. Try pulling the level’s name after you pull the element out.
Thanks Jacob.
It works with removing the level from the parameter list. But I don’t understand why I can get levels inside my room list but not window list.
Sorry to revive the post, but could you help me with the same error? What could have gone wrong?
Sorted out! I found the suitable node to convert.
