Hi all
So I’m pretty much a novice when it comes to dynamo and certainly haven’t a clue when it comes to Python unfortunately so any help would be very much appreciated, particularly if you can explain why I am going wrong and where.
I have tried to follow the below link from archi-lab, Konrad is ace with his explanations btw:
But even after rebuilding it from scratch with the updated nodes to reflect the later releases I am still getting the below error.
Please please help.
I have attached the script fyi.
wiprenamerooms.dyn (73.7 KB)
In past versions of the Revit API you could feed a string as a parameter name to get_Parameter but now it either expects a GUID (as per the error message) or you can use a builtin parameter in this case. Try this on line 65:
if to_room == None or f == to_room.get_Parameter(BuiltInParameter.ROOM_NAME).AsString()
For the subsequent lines you’ll need to replace "Name"
with BuiltInParameter.ROOM_NAME
and "Number"
with BuiltInParameter.ROOM_NUMBER
I had a go at the GUID version…
#Copyright(c) 2015, Konrad Sobon
#@arch_laboratory, http://archi-lab.net
#updated by MKA, thanks ADieckmann & TCorrie
# Import RevitAPI
clr.AddReference("RevitAPI")
import System
#get all built in parameters
bips = System.Enum.GetValues(BuiltInParameter)
pdata = list()
#loop through the built in parameter list
for bip in bips:
try:
# append the bips to a list as position 0, along with their id at position 1
pdata.append(bip,ElementId(bip))
except:
pass
rmNum = []
rmName = []
# look through the built in parameter list
for p in pdata:
# compare the bip (as a string) at position 0, to ROOM_NAME
if str(p[0]) == 'ROOM_NAME':
# if the bip matches ROOM_NAME add the GUID (at position 1) to the 'list' (we add position 0, so instead of a list containing the GUID, we get the GUID)
rmNum.append(p[1][0])
#if the name matches ROOM_NUMBER, add that as above
elif str(p[0]) == 'ROOM_NUMBER':
rmName.append(p[1][0])
filter_1 = IN[1]
fam_inst = IN[0]
elements = []
for i in IN[0]:
elements.append(UnwrapElement(i))
def TryGetToRoom(room, phase):
try:
toRoom = room.get_ToRoom(phase)
except:
toRoom = None
pass
return toRoom
def TryGetFromRoom(room, phase):
try:
fromRoom = room.get_FromRoom(phase)
except:
fromRoom = None
pass
return fromRoom
room_number, room_name, doors, room = [], [], [], []
for i in elements:
for phase in doc.Phases:
if i.CreatedPhaseId == phase.Id:
for phase2 in doc.Phases:
if TryGetToRoom(i, phase2) != None:
to_room = TryGetToRoom(i, phase2)
break
to_room = None
for phase3 in doc.Phases:
if TryGetFromRoom(i, phase3) != None:
from_room = TryGetFromRoom(i, phase3)
break
from_room = None
filter = 0
for f in filter_1:
#rmName is a GUID
if to_room == None or f == to_room.get_Parameter(rmName).AsString():
filter += 1
if filter > 0:
if from_room == None and to_room == None:
room_number.append("No to or from room")
room_name.append("No to or from room")
doors.append("No to or from room")
elif from_room == None:
#rmNum is a GUID
room_number.append(to_room.get_Parameter(rmNum).AsString())
#rmName is a GUID
room_name.append(to_room.get_Parameter(rmName).AsString())
doors.append(i)
room.append(to_room)
#rmNum is a GUID
room_number.append(from_room.get_Parameter(rmNum).AsString())
#rmName is a GUID
room_name.append(from_room.get_Parameter(rmName).AsString())
doors.append(i)
room.append(from_room)
#rmNum is a GUID
#rmName is a GUID
doors.append(i)
#Assign your output to the OUT variable
OUT = room_number, room_name, doors, room
