In sequence to my previous issue with creating rebar by the shape desired, I and trying to create rebar distribution by maximum spacing - using the “Structural Design” package node.
I am feeding in the required data and I am getting an error which I do not understand what is wrong…
rn you get 4 single Rebars out of the Create.FromCurve. Do you want that? If yes, then you need to be careful that the normal vector of all 4 single rebars is the same ( required input in that node).
If no, then change the lacing of the input CURVE from Create.FromCurve
I want to create a stirrup which should give me a closed rebar. There is a video that I am following that shows exactly the input and code which I followed therefore it should work.
The four lines is an offset of the face perimeter. The vector is composed of two points along the columns edge curve… I have now idea why the program is splitting the line into four separate lines…
