Floor.Create(Document, IList(CurveLoop), ElementId, ElementId) give two floors
Hi everyone !
Can’t understand why but my code returns two floors where I expect it to only create one.
For a bit more context, rooms and Curves lists do have the same length. listCurveLoop is a unique closed loop for each index i
I tried to place only an f = Floor.Create(doc, listCurveLoop, UnwrapElement(floorType).Id, rooms[i].Level.Id) inside the Transaction handler
I get only one floor in my log output but two in my Revit model
Here is the code :
import sys
import System
clr.AddReference("RevitAPI")
app = uiapp.Application
log = []
ERROR = []
Curves = UnwrapElement(IN[0])
floorType = IN[1]
rooms = UnwrapElement(IN[2])
for i in range(len(Curves)) :
    listCurveLoop = []
    for c in Curves[i] :
        newLoop = CurveLoop()
        for m in c :
            try :
                ri = m.ToRevitType()
                newLoop.Append(ri)
            except :
                pass
        listCurveLoop.append(newLoop)
    if listCurveLoop :
        try :
            log.append([rooms[i],[Floor.Create(doc, listCurveLoop, UnwrapElement(floorType).Id, rooms[i].Level.Id)]])
        except :
            ERREUR.append([rooms[i],sys.exc_info()[1]])
    else :
        ERREUR.append([rooms[i],"Invalid Curve"])
OUT = log, ERROR
I suspect I did something wrong with for loops but I can’t put my finger onto what and tried asking GTP for help which wasn’t successful
Thank you for the time taken to tackle this issue with me
Hi @Yorick try look into @GavinNicholls crumple package there is a node for that written in python so you can checkout how it can be done
Here is an example of a loop working with the output of Room.FinishBoundary for multiple rooms. Hope it helps. One key to this workflow is to ensure each object is represented in a list of list of list of curves (effectively a list of curveloops per object). Even if an element only has one list of curves, it has to sit at a predictable depth for iteration.
# Made by Gavin Crump
# Free for use
# BIM Guru, www.bimguru.com.au
# Boilerplate text
# Current doc/app/ui
# Define list/unwrap list functions
def uwlist(input):
	result = input if isinstance(input, list) else [input]
	return UnwrapElement(result)
# Preparing input from dynamo to revit
loopsList = IN[0]
typ = UnwrapElement(IN[1])
lvl = UnwrapElement(IN[2])
floors = []
for loopList in loopsList:
	curveloops = []
	for loop in loopList:
		crvs = []
		for crv in loop:
			crvs.append(crv.ToRevitType())
		curveloop = CurveLoop.Create(crvs)
		curveloops.append(curveloop)
	flr = Floor.Create(doc, curveloops, typ.Id, lvl.Id)
	floors.append(flr)
# Preparing output to Dynamo
OUT = floors
Hello guys !
Sooooo …
Problem solved, reopened my graph, haven’t made a change, re-ran it and it now works without the double floors issue ¯\ _ (ツ) _/¯
Tested on several projects with different type of geometry porblems (nurbs, small boundaries, …) works like a charm
Thanks for the time you put in trying to solve this !!
