Hi All
So my end goal is copying over revision clouds from one model to another in exact same location in same views which are present in both models. I have the model with clouds inserted as a link in the destination model.
I tried:
- Using BIMmorph LinkElement.CopytoActiveDocument didn’t work as revision clouds are view-specific elements
- Using Springs Document.CopyFromLinkInstance also didn’t work for same reason
- Modified the pyhton script from the springs node using chatgpt for view-specific elements didn’t work (I have very limited knowledge in python scripting and API).
- And weirdly, trying to recreate the revision clouds from scratch in destination model using extracted data from link model didn’t work too. I pulled the data for owner Views Id and revision cloud curves from link model, but using RevisionCloud.ByCurve node results in error (RevisionCloud.ByCurve operation failed. revisionld is not a valid Revision. Parameter name: revisionld). But I’m sure revision sequence is correct and it’s present in model where I’m running the script.
Any thoughts on how to make this work ? Either by copy clouds from link or re-creating them automatically using data from link?
