Hi, can you get an elements view? cant find a node for it. Specifically a callout referencing over views view. Or can you select callouts in view by category? Seems to give me emptys with view or callouts as category. Dynamo can take me to the view of the element so there must be some way to report it
Depending on the Elements Type, it can be tricky, especially with Views as they are just windows into the virtual model, that may span across multiple other views. This might get you started ![]()
thanks Ewan, been trying parameters and built in parameters but no luck for other refrenced callouts element. Would you be kind enough to post the code if you still have it up?
Sure ![]()
clr.AddReference('RevitAPI')
def GetOwnerView(item):
if hasattr(item, "OwnerViewId"): return item.Document.GetElement(item.OwnerViewId)
else: return None
items = UnwrapElement(IN[0])
if isinstance(IN[0], list): OUT = [GetOwnerView(x) for x in items]
else: OUT = GetOwnerView(items)
