Elements material name
Hi there,
I want to add a text to all of my material names,
As you see in the picture, I change my material names but how is possible to set new material name?
I tried to use setparameter
But I couldn’t find the material parameter name to set it.
Thank you
For parameterName use string node instead, and write down the name of the identity parameter, which should be Name, or Material Name
I tested both of them but it doesn’t work.
I don’t know what is the exact parameter name that use it in string node.
Hi @nia98bim try something here and see if it could work
Thank you, Element.setname is for a package or something?
Because I couldn’t find it before!
Could you send Element.Setname dyn node to me please?
Thta one is from clockwork …just intsall that package from package manager
I had this version of clockwork before but there is no element set name node in it.and old versions are unavailable,
even when you go here ? and be sure you have dynamoironpython 2.7 package installed ver. 2.5
arhhh now i think i know whats wrong, I see you have bakery installed, that package havent been maintance for year and gives conflick to other package…uninstall that and i guess it will work
thank you! :slight_smile:
