Hello guys ,
By this line i can get the current document " documentmanager.instance.currentdbdocument"
So i can pass this to filteredelementcollector so i can get elements of specific category of the current document , but how can i reach to revit link document so i can get elements of the link
Hi @eng.elfeky,
You’ll need to use FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_RvtLinks)
And after that how can i get the elements of a specific link
I dont know how firm you are to C# but take a look at this blog:
https://thebuildingcoder.typepad.com/blog/2013/09/access-to-individual-elements-in-linked-projects.html.
Thank you
What is the name of this package
Bakery and Steam nodes
Thank you
hello again ,
i tried this nodes and it worked but can i get elements from a specific link if i have many links? or is there any way to do that?
If you’d like to do this in Python without any 3rd party nodes, you can use the following:
clr.AddReference("RevitAPI")
current_doc = DocumentManager.Instance.CurrentDBDocument
links = FilteredElementCollector(current_doc).OfClass(RevitLinkInstance)
docs = [link.GetLinkDocument() for link in links]
OUT = docs
This will get all Revit link instances in from the current document and return all documents associated with the link instances. You can also append current_doc to the docs list if you want to evaluate elements from both the host document and the linked documents.
You can then pass all of these documents to the FilteredElementCollector() as you would with any other document. So, if you’ve already written a script that uses the FilteredElementCollector you won’t have to change much.
Good to know
