Why the Code “Elements.AreaLcation”(rtythm) is didn’t work with 2 Area schemes (Gross Building and Rentable)? I using Revit 2018.3 with Dynamo 2.0.3
Warning: Elements.AreaLocation operation failed.
Thanks,
Check if the node is asking for a Area Element instead of Room? Just a thought.
I’ll check it by myself when I’m near my computer again.
yea you will need to use the OOTB node, room.area node (if im not wrong). As both room and element object uses different .Area api.
