Elements in Room not Working
I’m trying to collect elements in a room.I want to put Room Number in each element(Pipe,Pipe fittings,Pipe accessories,Sprinkler etc). But its not working.Can please check my files and advise me.
Revit file
https://www.mediafire.com/?30dt5mfxuwhhxwo
Dynamo file
Elemens in Room.dyn (5.0 KB)
Thanks and Regards
hey bikashseas,
i took a quick look at your script, looks like te custom node with the python doesn’t work.
maybe you could take the boundery’s of the room and make a surface, thicken the surface with the height of the room and then try a geomerty intersect with al the elements.
Maybe it’s a bit of work, but it will work eventually.
I’m using “Elements in Space” from archi-lab and its working fine.
Thanks.
yeah… that would be the more easy way to go.
