Element.Setname on Components node broken in Revit 2022 / Dynamo 2.12?
Hello! I’m trying to run a simple graph to change type names:
This graph has functioned several versions back, but now the node doesn’t succeed with any placed Family Instances if data is read from the instances… System Families still works as expected though. It also works if the node is fed a simple list not associated with any objects. Have anoyone had the same problem? Or maybe an alternate solution to changing Type Names?
Hello and welcome to Dynamo forum…is it the node from Clockwork ? strange it works here and im in 2022 as well…
Can you show what your previews look like for each node?
Graphs with previews ahead :slight_smile:
Interestingly the solution outlined by @sovitek works:
But as soon as data is extracted from the elements the last node fails:
The identical graph works as expected in earlier versions
Think you had illegal characters
Try to remove : and it should work…Held og lykke med det :wink:
That’s it! thanks a lot @sovitek
