I am trying to create a script to easily change an element’s material such as Element.OverrideColorInView But with a material instead of a color.
Any suggestions? Best
To my knowledge you can’t override a material (with another material).
If you have to change an element’s material I would suggest using the paint-option.
I have here an example using a paint method with py. script by René Castillo Picazo.
The only problem with this is that when the element is painted it can’t be painted again without the paint being removed first.
A Removing paint script or a modification of script below would solve the issue.
# Copyright(c) René Castillo Picazo
# México 2017
# cadesigner.mex@gmail.com
clr.AddReference("RevitAPI")
surfaces = IN[0]
material = UnwrapElement(IN[1])
def PaintFace(surf, mat):
elemRef = surf.Tags.LookupTag("RevitFaceReference")
elem = doc.GetElement(elemRef)
face = elem.GetGeometryObjectFromReference(elemRef)
if not (doc.IsPainted(elem.Id, face)):
return doc.Paint(elem.Id, face, mat.Id)
if (isinstance(surfaces, list)):
[PaintFace(j, material) for i in surfaces for j in i]
PaintFace(surfaces, material)
