This is my first post here as I’m starting to dip my toes into the Dynamo waters. I’ve seen some really great ideas and help from this forum, so I hope someone can point me in the right direction.
I’m having trouble taking a list of Element IDs (list “A” in the image below) and converting them into elements (in this case, they’re walls). When I try to convert them (B), I get no matches ©.
I tried a workaround where I grabbed all the walls in the project and then pulled their Element IDs (D). I wanted to pare the entire list down to only the ones I needed from the first list (A) by first finding the index number of each item, then I’d eventually list them by index to get them in the same order as the first list (A). I thought “IndexOf” (E) would have been how to do it, but I keep getting an output I wasn’t expecting (F). I tried manually inserting an Element ID number as an input into IndexOf and it worked fine… so I think I’m misusing my list somehow.
Anyways, I’m totally stuck. I’ve tried every workaround that I could think of but haven’t progressed.
Any help would be greatly appreciated!
