If I have a thousand notes- Trying to translate to bilingual- yes keynotes are the goal-
are the GUID or UUIDs in Revit (Element ID) Static or do they change?
(Does this still apply?
http://dynamobim.org/forums/topic/revit-id-guid/)
The Element ID can change in a project. Mostly when the project is a “collaboration project”.
It would be best to go for GUID is you are needing to work with elements over a period of time and/or in and out of other software like Excel. The GUID will not change as long as the element is not deleted / recreated.
Thanks @SeanP That was the verification I suspected but needed : )
Ended up where OBJ is an unwrapped element from IN[0]
#Get GUID
objGUID=obj.UniqueId
