Element Bounding Box midpoint shows far away from element
bb = element.get_BoundingBox(None)
   if bb:
      midpt = ((bb.Min + bb.Max) / 2).ToPoint()
Above code shows bb mid point far away from element categories(windows, electrical fixtures, etc…) which has witness lines or dimension reference lines, how to get BB midpoint of element ignoring these?
@mmkkmmv ,
check out this topic
could also be that your family is not clean modeled. thats essential to keep the box “skinfit” to your element.
KR
Andreas
@Draxl_Andreas
Not working for element or family instance which has witness lines, I am using Dynamo python script node for this, but how to ignore element witness lines for bounding box midpoint to be on element itself?
Are you trying to get the midpoint of a linked model element?
First generate a new view, then disable the lines categories in that view. Use that view when pulling the bounding box and it should omit the curves. Once the bounding box is taken you can delete the new view.
@pyXam not from linked model element, from direct model element
I take it back - you can’t just hide the linework, but rather need to pull the bounding box from the solid geometry.
There is a code sample here in C#, which you should be able to translate without much issue: Solved: Revit API get bounding box around door geometry (excluding swing) - Autodesk Community
@jacob.small I am using revit dynamo python script node for this
Yes. You will want to translate the C# code into Python. Not a two second task, but not insurmountable.
import sys
import itertools
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference('ProtoGeometry')###REMOVED FOR error, 2 lines only
from Revit.Elements import Element
clr.AddReference("RevitAPI")
clr.AddReference('DSCoreNodes')
from DSCore.List import Flatten
app = uiapp.Application
inputElements = IN[0]
view1 = doc.ActiveView
opt=Options()
opt.ComputeReferences = False
opt.IncludeNonVisibleObjects = False
#opt.View = view1
def get_bb_mid(ele):
	bb1 = None
	geo = ele.get_Geometry(opt)
	for a in geo:
		geoInst = a.GetInstanceGeometry()
		for g in geoInst:
			if isinstance(g, Solid):
				bb1 = g.GetBoundingBox()
				if bb1:
					break
	return bb1
centroid_lst = []
for ele1 in inputElements:
	#ele_typ_id = ele.GetType()
	ele = UnwrapElement(ele1)
	pt1 = get_bb_mid(ele)
	centroid_lst.append(pt1)
OUT = centroid_lst
tried above
getting boundingboxXYZ, i need one mid point on element
Your previous code for the middle of the bounding box should work now.
That said, keep in mind that the middle of the bounding box may not fall inside of the solid geometry.
@jacob.small I need one near midpoint on element itself not outside of element geometry, any suggestions?
Would need a sample of the geometry to see the best path forward. Post the RVT with one or two instances in it and I’ll have a look later.
Sending Rvt file may take time, but i observed that, if I move witness lines near to element, bounding box midpoint is near to element & this may work for me, majority elements are familyInstances which has this issue, how to ignore these witness lines to get element BB midpoint?
Review the C# code previously provided. Or filter out non-solids from the list of geometry, union the remaining solids into a single solid, and pull the bounding box from the single solid.
a solution by summing the bounding boxes of the solids
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
def get_midBBX_byGeometry(elem):
    # sub function
    def get_solid_bbx(solid):
        box = solid.GetBoundingBox()
        origin = box.Transform.Origin
        box.Min = box.Min.Add(origin)
        box.Max = box.Max.Add(origin)
        return box
    # main function
    opt=Options()
    boxes = []
    geoSet = elem.get_Geometry(opt)
    for geo in geoSet:
        if isinstance(geo, GeometryInstance):
            for gi in geo.GetInstanceGeometry():
                if isinstance(gi, Solid) and gi.Volume > 0.01:
                    boxes.append(get_solid_bbx(gi))
        elif isinstance(geo, Solid) and geo.Volume > 0.01:
            boxes.append(get_solid_bbx(geo))
            pass
    geoSet.Dispose()
    minx = min(boxes, key = lambda x : x.Min.X).Min.X
    miny = min(boxes, key = lambda x : x.Min.Y).Min.Y
    minz = min(boxes, key = lambda x : x.Min.Z).Min.Z
    maxx = max(boxes, key = lambda x : x.Max.X).Max.X
    maxy = max(boxes, key = lambda x : x.Max.Y).Max.Y
    maxz = max(boxes, key = lambda x : x.Max.Z).Max.Z
    midpoint = XYZ((minx + maxx) / 2.0, (miny + maxy) / 2.0, (minz + maxz) / 2.0)
    return midpoint
elem = UnwrapElement(IN[0])
OUT = get_midBBX_byGeometry(elem).ToPoint()
Thanks, will check
Hi there,
I recommend using the Archilab Package GetCentroid method; it worked for me when I encountered the same issue.
Edit-
Supplying the model elements directly to this node will do the job and no need to get the bounding box from Element.
Can i select element automatic with this centroid whether element present or not in python node?
@NIRMAL
i cant answer directly ... i cant find in the API GetCentroid
import sys
clr.AddReference('System')
#functions
def tolist(x):
    if hasattr(x,'__iter__'): return x
    else: return [x]
elements = UnwrapElement(tolist(IN[0]))
output = []
for i in elements:
	output.append(i.get_Geometry(Options()))
OUT = output
i get this just with Centroid
#functions
def tolist(x):
    else: return [x]
output = []
for i in elements:
	output.append(i.Centroid)
OUT = output
KR
Andreas
