I’ve gone through the verbose version of making a definition - that works fine. It is, however, exceedingly bloated. I was wondering if anyone would care to share their thoughts on arriving at the same geometrical output that I have?
I’ve attached a series of images of how I got to the end result. The premise is relatively simple:
Four points at Ceiling level - can change via sliders
Four points at top of Column level - can change via sliders. Rotated 45° from the first series of points.
Lines taken from each Ceiling points to the centrepoint (0.5 parameter along curve) of the Column points.
Lines taken from each of the Column points to the centrepoint (0.5 parameter along curve) of the Ceiling lines.
Offset based off a slider for points at 0.25 along curves between Ceiling and Columns.
Nurbs curve created after some List Manipulation to gain arcing curves.
Nurbs curves divided to form 'smoothing/divisions' and lines created between these points.
Polysurfaces created from each of the line segments.
For some reason Code Blocks don't seem to be working for me in the pre-release build (Or I would have conjoint a whole bunch of Point.ByCoordinates(X,Y,Z)'s together, Lines.ByStartPointEndPoint together etc). Beyond that, what kind of major efficiencies am I missing? Or is my thought process dubious and misinformed? :)
I replicated your definition and have ran into a small problem that I can’t seem to fix because I know it’s correct!
The final Geometry.Rotate is failing with the Code Block input of: 90…360…90; (As shown below in the image)
If I simply put in 90, 180 or 270 in singular form into the ‘degrees’ input of Geometry.Rotate it functions perfectly.
I’m a little stumped… I even tried RadiansToDegrees and DegreesToRadians thinking that might be the problem and we through every node’s output to check it made sense (Which I believe it does).
The image below shows what occurs… kind of seems like a lacing problem even though it shouldn’t be?
90…360…90 means {90,180,270,360}, so the code block makes 4 rotated geometries of each(two in this case) geometries in the list when you select Cross Product lacing.
BTW, this thread inspired part of my blog post on tips and tricks last week. Though not specifically algorithm-oriented, as your question is, here are some thoughts on organizing your graph using Code Blocks several different ways.
Hi Kim.
Could you tell us if there is a way to create a surface with six openings. This one is having just 1. Could you share a way to create 6. Thanks
