Hello guys, anyone knows how to edit already created room boundry line in revit without having to delete to recreate the boundry from scratch?
give example of the issue
You did not create a room boundary manually. You have created room bounding elements (it could be walls, room separations, concrete columns). Why would you want to change the room boundary and what exactly?
Hi @khaliboay have you build your room with separationsline ?
I have used the room seperator for rooms that could not be automatically generated. Can i edit the
seperator?
Yes
You could delete the existing separators in dynamo and place new ones from curves. But pls be as specific as possible.
This might be relevant to your interests: Dynamo Dictionary
Alright, thanks
Ok thanks, will try this.
