Editing Linked CAD Graphipcs Configuration
Hi every one!!
Id like change color and weight oh linked CAD lines.
Ive found one node in bimorphNodes that work fine:
But it work only for one linked CAD, id like edit a list of linked CAD, but dont work:
In htis last case not all linked cad are changed…
Any susgestion?
Thanks in advance
Try right click CAD.SetObjectStyle and change lacing to longest.
Also, check your list ordering so lacing works as expected - the indexing needs to align. So “TABLAS” and lineweight 1 will update the import instance at index 0 in your List Create node (all indexes @ 0 get matched, followed by 1 and so-on). If its not working, its likely to be caused by a mismatching between your list order, i.e. TABLAS is a layer in the second import instance (index 1 of your list) not the first (index 0).
Ok thaks a lot
Ill try it!!
hi, i want to change the line type link cad in revit view. can it happen if i use your code as my reference?
