Edit Workplane of object
Hi there :slight_smile:
I am struggling to find a way to edit the workplane of an object.
Does anyone know if this is possible?
It is my goal to update the workplane, because currently, I can only create a new object (with a new workplane) and copy all parametervalues over which does not seem to be a clean solution at all :frowning:
Looks like setting the workplane may only be available via postable command, which means not really doable en-masse for families the way you’ve requested.
Recreating the family in the location with the correct workplane, copying over the relevant parameters, and deleting the previous instances is the route I’d go (not as big a limitation as one would first think).
Thanks, I was hoping there were any news for Revit 2021 regarding this topic :frowning:
