Hi everyone
I´m stuck again
I try to change the workplane of a cutout to the level of the object it is colliding with. I copied the file from another file and now it has an offset of 18.4 and uses the 0.0 Level to place the object. I wish to change this by changing the work plane of this object and changing the offset corresponding to the level elevations.
My problem is the following. I don´t find any node which is able to set the workplane of an object and the revit api only has “SetWorkplane” here: https://www.revitapidocs.com/2018.2/f6ccdc1b-6ac3-9c49-d0bb-8a7d1877eab0.htm
But it does not really seem to be a proper function?!
Does anyone know how to solve this problem?
Thanks a lot and kind regards,
Jannis
_temp_change_workplane.dyn (24.1 KB)
