I work on Python script that creates and edits schedules.
I wish to edit the headings of schedule columns - the row that contains the parameter names, below the schedule title. It can be overridden to any other text in UI. As far as I understand, it is the row no. 0 of the Body type of TableSectionData.
I can successfully edit the schedule title, however, when I try to edit the column headers I get the exception “ This operation is forbidden for cells in standard schedule body sections.”.
Does it mean that you cannot really edit this row through API, even though you can edit it with UI?
Please see a part of my code (choosing any schedule in the model and trying to override first cell in the column heading).
clr.AddReference("ProtoGeometry")
# Import RevitNodes
clr.AddReference("RevitAPI")
# Import Revit elements
from Revit.Elements import *
# Import DocumentManager
import sys
app = uiapp.Application
adoc = doc.ActiveView
schedule = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Schedules).WhereElementIsNotElementType().FirstElement()
tableData = schedule.GetTableData()
tableBody = schedule.GetTableData().GetSectionData(SectionType.Body)
tableBody.SetCellText(0, 0, "MY TEXT")
I managed to find solution on my own.
Editing the column headers is possible, but in a different way.
In case anyone would have similar struggle, I’m leaving solution: it worked for me to edit the ColumnHeading property of ScheduleField class, instead of trying to set the cell text.
This is how I got it working, just sharing for others:
# Add necessary Revit API references
# Access the current document
# Retrieve the list of ViewSchedules from Dynamo input
viewSchedules = [UnwrapElement(sched) for sched in IN[0]]
# Mapping dictionary for old headers to new headers
mappingDictOldNew = IN[1]
# Start a transaction to modify the document
try:
# Iterate over each ViewSchedule in the list
for viewSchedule in viewSchedules:
# Get the number of fields in each schedule's definition
nFields = viewSchedule.Definition.GetFieldCount()
for n in range(nFields):
field = viewSchedule.Definition.GetField(n)
# Get the current column header
currentHeader = field.ColumnHeading
if currentHeader in mappingDictOldNew:
# Get the new header from the mapping dictionary
newHeader = mappingDictOldNew[currentHeader]
# Update the column header
field.ColumnHeading = newHeader
print(f"Changed header from {currentHeader} to {newHeader} in schedule '{viewSchedule.Name}'")
except Exception as e:
TransactionManager.Instance.ForceCloseTransaction()
OUT = "Error: " + str(e)
OUT = "Headers updated successfully."
