Hi All, I found a node ‘Schedule Formatting’ but can’t seem to work. Any advise on the matter?
Welcome to the community! Looks like there is an issue in the code not being able to iterate through a bool for the hidden input and an integer for the column width input. You may can try searching for an update to the archilab package. Or if you are only wanting to rename the column header, then you can use the code below. Input the schedule, the header name to be replaced and the name to change it to.
clr.AddReference('RevitAPI')
sched = UnwrapElement(IN[0])
names = IN[1]
newNames = IN[2]
fields = sched.Definition
for number in range(fields.GetFieldCount()):
colHead = fields.GetField(number).ColumnHeading
for n, newName in zip(names, newNames):
if colHead == n:
sched.Definition.GetField(number).ColumnHeading = newName
OUT = sched
here is a solution with a dictionary and Python
code Python (compatible with all engines)
#import Revit API
def toList(x):
if isinstance(x, list):
return x
elif hasattr(x, "GetType") and x.GetType().GetInterface("IEnumerable") is not None:
return x
else :
return [x]
viewsSchedules = toList(UnwrapElement(IN[0]))
repDsDict = IN[1]
try:
#convert DynamoDictionary to PythonDictionnary
repPyDict = dict(zip(repDsDict.Keys, repDsDict.Values))
except:
repPyDict = repDsDict
for view in viewsSchedules:
if view.ViewType == ViewType.Schedule:
schedulDef = view.Definition
lstfieldId = schedulDef.GetFieldOrder()
for fieldId in lstfieldId:
scheduleField = schedulDef.GetField(fieldId)
valuefromdict = repPyDict.get(scheduleField.ColumnHeading)
if valuefromdict is not None:
scheduleField.ColumnHeading = valuefromdict
OUT = viewsSchedules
Thank very much!
