Does anyone know of a way to get data from a schedule title cell?
I’m using dynamo to export electrical element data to excel so they can be edited by a non-Revit user. We insert cells in the Revit schedule title to input schedule notes. I’m looking for a way to include the that specific cell in the data that I’m exporting to allow the non-Revit user to edit the schedule notes. I would then like to import that back into Revit. Does anyone know if this is possible?
Use this link and combine it with the changes for the SectionType below and I think this may get you what you want:
TableData td = vs.GetTableData(); // get viewschedule table data
TableSectionData tsd = td.GetSectionData(SectionType.Header); // get header section data
string text = tsd.GetCellText(0, 0);
tsd.SetCellText(0, 0, "my new title");
clr.AddReference("ProtoGeometry")
# Import RevitNodes
clr.AddReference("RevitAPI")
# Import Revit elements
from Revit.Elements import *
# Import DocumentManager
import sys
app = uiapp.Application
adoc = doc.ActiveView
schedule = UnwrapElement(IN[0])
row = IN[1]
column = IN[2]
#get viewschedule table data
td = schedule.GetTableData()
#get header section data
text = tsd.GetCellText(row,column)
OUT = text
Line 48 replace Header with Body. Header is used for the data above the A, B, C, etc. column markers. Body is used for data below that.
It should read: tsd = td.GetSectionData(SectionType.Body)
I was getting header cells (rows inserted below the title cell row) information with my code above. Also, if you’re looking to output all of the headers into a list, you’ll need to have a loop in your python code.
