Can Dynamo edit the formula for a parameter?
I’m working on a family that might use anywhere from 2 to 20 visibility parameters, and then one big “OR” statement that contains all of them.
If I only need 2 options, I’d rather not trash up the family with 18 I don’t need. But that would mess up the OR.
Unless I can edit/build that formula in Dynamo
Hi @DaveP,
Yes, you can get and set the Parameter Formula with the API…
http://www.revitapidocs.com/2017.1/cdc3156c-0334-0bba-70af-1df78fb18b50.htm
So in theory, you could create a string by concatenating the param names and OR/IF/AND strings to create a formula.
I’m not near a PC so can’t code it up right now, maybe there is a node in one of the packages already but I’m guessing you’ve looked quite a bit?
Could you elaborate a little more about what you are after though? If you have examples of what you are trying to create, post them here. Pictures work well!
Cheers,
Dan
Hi @DaveP,
Given a computer and 5 mins I quickly made this script that allows you to Set the parameters formulas. Here is a quick example from my testing…
The Script:
SetParameterFormula.dyn (11.7 KB)
Before:
After:
You can use your own logic to get what you are after. Let me know if you have any problems.
Cheers,
Dan
Hi Dan,
How to set the formulas for Text parameters?
