Easy to do it manually, but can it be done proramatically?
I need to do this ask… Just a little help on how to do it in dynamo? or code block?
With the API and Python.
Don’t know if anyone has made a node for these.
I saw this one… I just need to figure out how to read it…
clr.AddReference('RevitAPI')
if IN[0]:
	unit = doc.GetUnits()
	format = FormatOptions(DisplayUnitType.DUT_MILLIMETERS, 0.01)
	unit.SetFormatOptions(UnitType.UT_Length,format)
	doc.SetUnits(unit)
	OUT = "length unit changed to millimeter"
	OUT = "Set IN[0] to true!"
For future reference, please post code inside preformatted text (</>) so that it gets formatted properly.
1 unit = doc.GetUnits()
2 format = FormatOptions(DisplayUnitType.DUT_MILLIMETERS, 0.01)
3 unit.SetFormatOptions(UnitType.UT_Length,format)
4 doc.SetUnits(unit)
  1. Get the project units.
  2. Get the type of units and rounding.
  3. Format the unit type and rounding for the specified unit.
  4. Apply the unit formatting back to the project units.
Thanks for the explanation… but is there no 5? Set the “unit symbol” to none…
I was just explaining those lines of the code you posted. In order to change the symbol display you would also have to use the FormatOptions for UnitSymbolType.
https://www.revitapidocs.com/2020/1058a15c-711c-db20-3f11-c9c6a71f113c.htm
Awesome, exactly what i need… thank you
so why is it that it worls in R20 but not in R22 ? change in API?image
Exactly.
Units were transitioned to ForgeTypeIds. This is the new method:
https://www.revitapidocs.com/2021.1/64822a98-a253-3300-cdbb-17973687878f.htm
Just to complete this thread… The similar solution was found here.
