I’m trying to find a node/script that can change a documents unit type.
For example, changing the “distance” project units to imperial to metric:
I’ve tried tutorial on Youtube but they don’t work with the new api.
Thank you very much!
I don’t think there is a node that will update units
Here is some python code that can
clr.AddReference("RevitAPI")
units = doc.GetUnits()
length = SpecTypeId.Length
feet_fi = UnitTypeId.FeetFractionalInches
current = units.GetFormatOptions(length).GetUnitTypeId()
if current != feet_fi:
units.SetFormatOptions(length, FormatOptions(feet_fi))
current = LabelUtils.GetLabelForUnit(current)
updated = LabelUtils.GetLabelForUnit(
doc.SetUnits(units)
OUT = current, updated
another example with Distance and Length unit
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import transactionManager and DocumentManager (RevitServices is specific to Dynamo)
def set_millimeter_Unit():
unit = doc.GetUnits()
format_opt = FormatOptions(Autodesk.Revit.DB.UnitTypeId.Millimeters)
format_opt.Accuracy = 1
unit.SetFormatOptions(SpecTypeId.Distance, format_opt )
unit.SetFormatOptions(SpecTypeId.Length, format_opt)
doc.SetUnits(unit)
