CC: @Aleksey_Lobanov
Hi, pvhuyg
Please attach your dyn files and explain all details about this issue (when it is caused, is this actual for all scripts or for only one and so on)
Revit 2017.2
pvhuyg,
I have the same issue.
Hi pvhuyg
Please try to install and use this test build https://yadi.sk/d/lyhJjWmW3Kb4FG
I have changed init Dynamo core technique. Because last Dynamo versions have some new options in the core starting process.
I will be waiting your test result!
thank you
the bug has been fixed
