Hi All,
i try to get clash group results from NWD file. the node is able to get (incorrect) names for 2 from 4 clash tests. other 2 tests gives NULL lists (although groups are defined there as well). the only difference i can find between 2 “success” clash test and 2 “failed” is that in the wrong ones two groups contains that have status APPROVED. Can this be a reason why the “ClashDetection.GetClashGroupResults” fails??
have anyone experienced similar problems? or success with
this node?
Thanks,
Jarek
