Hello, trying to work with the example graph for DynaSpace (here: DynaShape/Examples/DynaSpace/DynaSpace_Example.dyn at main · LongNguyenP/DynaShape (github.com)). Initially it works but then seemingly randomly it will fail and look like this
(DynaShape/Examples/DynaSpace/DynaSpace_Example.dyn at main · LongNguyenP/DynaShape · GitHub) eg color coding, space id’s will disappear and graph can not be manipulated by dragging space bubbles. Manipulation, Show Space Ids and Show Adj Space-Dept and Execute are all still set to true. is it an issue with Dynamo struggling to load properly or is it my fault? i’ve had the same issue with 3 different versions of the graph ive opened that initially work fine and then failed, i cannot remember changing anything that may make it fail like that. any suggestions are appreciated!
Check if manipulation is on (can’t work with silent mode if I recall), and that you’re in Automatic run mode.
that did it! thank you again! follow up question. i got generative design to work by feeding it a list of random initial positions with random seed as input, but all outcomes come out blank missing the space bubbles (
, as far as i can tell all relevant previews are toggled on, is there another setting I am missing?
Can’t tell, but likely. Best to start a new topic if you’re still stuck after trying some of the settings. Remember you’ll need the silent run mode again.
