Dynamo log started 2013/10/26 17:58:03
Exception encountered scanning the package directory at C:Program FilesAutodeskCoredynamo_packages
System.Exception: C:Program FilesAutodeskCoredynamo_packagesDynamo Sample Custom Nodespkg.json contains a package without a header. Ignoring it.
Dynamo – Build 0.6.2.11703
Failed to load type from DynamoCore, Version=0.6.2.11703, Culture=neutral, PublicKeyToken=null
The type was Dynamo.Nodes.DSFunction
System.ArgumentOutOfRangeException:
Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
at System.ThrowHelper.ThrowArgumentOutOfRangeException()
at Dynamo.ViewModels.SearchViewModel.AddCategory(String categoryName)
at Dynamo.ViewModels.SearchViewModel.Add(Type t)
at Dynamo.Utilities.DynamoLoader.LoadNodesFromAssembly(Assembly assembly)
Duplicate type encountered: Select Level
Could not load types.
System.Reflection.ReflectionTypeLoadException:
Unable to load one or more of the requested types. Retrieve the LoaderExceptions property for more information.
at System.Reflection.RuntimeModule.GetTypes(RuntimeModule module)
at System.Reflection.RuntimeModule.GetTypes()
at System.Reflection.Assembly.GetTypes()
Dll Load Exception: System.IO.FileNotFoundException: Could not load file or assembly ‘NeonRenderingServiceAPI, Version=2014.0.0.0, Culture=neutral, PublicKeyToken=null’ or one of its dependencies. ???
File name: ‘NeonRenderingServiceAPI, Version=2014.0.0.0, Culture=neutral, PublicKeyToken=null’
??? [HKLMSoftwareMicrosoftFusion!EnableLog] (DWORD)??? 1?
??? [HKLMSoftwareMicrosoftFusion!EnableLog]?
All Tests Passed. Core library loaded OK.
Welcome to Dynamo!
00:00:02.7863521 elapsed for loading Dynamo main window.
