i’m blocked with my 3D Templates.
i’m using the Node : ꟿ Collect.View3DTemplates and it’s working well but the elements at the end are not analysed by this node : Views.SetWorksetVisibility
I want to manage the worket’s visibility depending on the function of my 3D View…
Can you help me ? Thanks,
Can you show what you have so far?
The same script works with 2D ViewTemplates
Hello @Edouard.Guillemot …try to insert this one after your worksets name…
I think, the problem comes from the 3D Views because the node “Views.SetWorksetVisibility” is waiting a view and not a Revit.Elements.Element …
Good morning,
I am not sure how you collect your 3D views but using this way worked for me :
You are setting existing 3D views, not 3D Templates ?
The solution might be creating a 3D view by 3D Template and then modify them. I’ll try this…
“Element Types” Node does not get 3D templates, it’s why i’m using “ꟿ Collect.View3DTemplates”
From what I read, it’s quite a pain to deal with 3D viewtemplate. There is a workaround exposed in this answer :
Why do you even need a 3D View template? You can apply a plan view template to a 3d view and it works just fine. Whatever the issue is, it’s just best to avoid these half-baked templates because they have no purpose.
Ps. I would consider what you are trying to accomplish. You are applying the view template to a 3D View. The idea here is that you apply that view template, and then export that view to Navisworks. It sounds honky dory in theory, but I have a feeling that for a View template to act…
Don’t use “ThreeD” viewtemplate, use “FloorPlan” viewtemplates instead.
yes… i already found this solution, but it’s not very friendly…
Thanks for your help
Hello have you achieved something so far? I’m facing the same issue, thanks.
