Hi there, I’m working on a project to create some furniture families for a manufacturer. My target is to have a good balance between file size and model geometry so that these families can be used to output nice 3d renderings as well.
So far, I’ve been able to receive the STEP files, clean them up, and export them as SAT so I can model the Revit components (that needs to be on Revit 2018)
But now I need to model some caster wheels like the one shown in the screenshot attached. It has quite a complex organic geometry, so I believe I need to create it in the adaptive component environment.
My idea is to break the caster geometry into small parts like (‘tires’, wheels, brake pedal, and so on).
I saw a workflow where a guy recreates complex geometries on Revit, manually (!), by defining a set of ref planes, tracing intersecting splines on each ref plane, and then creating a form using those curves.
It provides a nice result and a low file size, but it’s extremely time-consuming. So I want to use Dynamo to speed-up things and have, at least, the splines drawn for me: selecting the geometry and the ref planes, setting an intersection, and then drawing the splines back on Revit.
How to draw these splines on Revit?
And other than that, do you know another workflow to get this ‘translation’ of imported SAT geometry done?
Thanks in advance!
