Dynamo Solid to Revit not showing in Revit
Hi I tried to convert Dynamo Solid to Revit using FamilyType.ByGeometry node. The preview in Dynamo is ok but when I check the Revit file is not showing. Any nodes I missed? I’m new to dynamo so help will much be appreciated.
Hello @dmorta … and welcome to our community!.. try this one here from springs it create the instance family…hope it will work…
Thanks a lot. I will try this node and give you a feedback.
It’s not working.
How many solids do you feed in ? every solid need an unique name…are you in 2022 ?
I only want to create a solid. Yes im in 2022.
allright…springs package isnt updated yet for 2022…but then you could try this here…have not tested on 2022…but hope it will help…
Still not working. I just used 2021 then maybe it will work. Thanks a lot for you help.
It’s working in 2021. Thanks a lot for your help.
Great…but should work in 2022 as well…strange :wink:
