Trying to important excel sheet names and numbers using dynamo, but the view use of the sheets seems to be getting in the way? has anyone had this issue ?
Check out @Daniel_Woodcock1 Post on this forum post. Its a much better way of going about making sheets.
But if you do want to uses the Sheet.By… Node you just need to plug a view into the last option. Uses Views (Built in node) and select a view that is already placed on a sheet (I like the vicinity map). Should work fine as long as everything else is in order.
