Dynamo Scripts not updating output functions when a change is made in Revit
This is because Dynamo doesn’t update many nodes unless an input changes, which is almost a requirement to develop scripts for large datasets.
Adding a true/false, number slider input or other easily adjustable input in conjunction with a list.create and list.first item early in the graph will allow a toggle to force a refresh. I believe that Clockwork also has a node for this.
