Anyone can help if someone have a code to input a x in opennings in slabs?
Hi @RafaelMarinado try with element geometry + from clockwork it can take the opening geometry
another way could probaly take the floor surface and the perimeter curves
arhhh ok could you share a small sample rvt with that
testezxzz.rvt (4.1 MB)
it have the family opening in floors, or in portuguese corte de abertura de piso, if u select the square on the floor
cheers, yes its a opening cut, but not sure do you want make the cross with detail curves or an annotaton family if so do you have a family
automatic detail curves would be easier for different shapes of openings
do you want cross in the round opening as well
nope, just on rectangle, this square was last model on TQS i forgot to remove before putting on revit
ok…i give it a shot later today or early tomorrow, im actuelly on vacation today. ![]()
sure, thank you very much for the help!
Good morning sovitek, it worked properly now! thank you very much
