Dynamo Revit element doesn't show in Revit
when I model an element inside dynamo it doesn’t show in revit
At the bottom of the wall by curve node you can see the element ID in green if I am correct.
What happens if you click on the ID?
Dynamo should find a view where the wall is visible
It say " no good view could be found "
Is the view depth correct?
Are there any filters or worksets that might cause the wall to be invisible?
You could try a 3d view to better locate where the wall actually is
I tried 3d and all I found is this line
That narrows it down a bit I guess…
Unfortunately I have no experience with placing walls by curves so I think you will have to wait for someone else to read your topic.
I am just guessing here but are you sure that line is created by dynamo?
I can see your 3D view has a structural discipline and a generic 300mm wall isn’t a structural wall by default if I am correct.
Can you change your discipline to architectural and see if that makes your wall visible?
Thank you,
I Changed the discipline to coordination and found the wall
