I want to use Dynamo with Revit to create tools, such as a tool that "extends columns to the base offset of a user-specified wall"
but I don’t want it to be fully automatic, I want the user to be able to select a bunch of columns, and then press a tool button, and have code prompt the user to select a target wall to extend the columns to.
So,
- Can dynamo make code-snippets into Revit buttons on a custom ribbon interface tab?
- Can dynamo prompt the user to select something, wait for them to do so, and then use the active selection for an algorithm?
- Can dynamo incorporate error handling (so that if the user selects the wrong element type, Revit/Dynamo displays an error message)?
