Hi, like John mentioned, if you are taking the geometry from liked file, you might need to translate it first. There are many nodes doing just that in Spring nodes, Archilab, Bimorph, etc. I struggled with the same issue before, you could check this topic:
Related topics
| Geometry from linked file, by shared coordinates, appears on the wrong place in Dynamo | 23 | 3106 | September 9, 2025 | |
| Dynamo symbolic line geometry generating in wrong location | 3 | 134 | February 23, 2024 | |
| Rooms from links are shifted | 5 | 408 | June 3, 2022 | |
| Curves of rooms from linked model are in another position (same survey point) | 1 | 151 | February 9, 2023 | |
| Creating Accurate wall geometry from Revit link | 4 | 582 | February 5, 2020 |
