Hi, can I get some help from here?
Before many thanks for your any reply.
Question 1:
I have defined a def in python but its aways with warming - unexpected token ‘newline’, see the below snapshot. (This script is work to creat a default 3d view.)
Question 2:
Here is another script also with some issue - aways with the blow snapshot warming.
(This one is work to create some view filter.)
And here is the Python script includes two def be defined.
import System
doc = revit.ActiveUIDocument.Document
# Get category list of the project parameter
def _GetParamCat(param):
# Collect parameter and category list
params = []
cats = []
iterator = doc.ParameterBindings.ForwardIterator()
while iterator.MoveNext():
params.append(iterator.Key.Name)
thesecats = []
for cat in iterator.Current.Categories:
thesecats.append(Category.GetCategory(doc,cat.Id))
cats.append(thesecats)
#Return category list
if param in params:
return cats[params.index(param)]
return ["%s is not a parameters name" %(param)]
def _CreatParamStrEqFilter(param):
cats = _GetParamCat(param)
#DB transaction
tran = Transaction(doc,"Creat ID Filter")
tran.Start()
#Get parameter from parameter category List
Elemcollector = []
for i in cats:
collector = FilteredElementCollector(doc).\
OfCategoryId(i.Id).\
WhereElementIsNotElementType().ToElements()
Elemcollector.extend(collector)
#Get all parameter values
pvalues = [""]
for elem in Elemcollector:
para = elem.LookupParameter(param)
pvalues.append(para.AsString())
pvalue = list(set(pvalues))
#Creatd a new rule
rules = []
for i in pvalue:
rules.append(ParameterFilterRuleFactory.CreateEqualsRule(para.Id,i,False))
#Typed category list ------- Important!!!
ids1 = list()
for i in cats:
ids1.append(i.Id)
catlist = List[ElementId](ids1)
rulelist = List[FilterRule](rules)
#Create parameter filter elmenets
filters = []
for i in pvalue:
if len(i) == 0:
name = 'Id - ' + i
name = 'Id - Empty'
filters.append(ParameterFilterElement.Create(doc,name,catlist,rulelist[pvalue.index(i)])
tran.Commit()
return filters
a = _CreatParamStrEqFilter("ACTIVITY ID")
print a
