Hi Guys,
I got a problem and can not understand why it happens like that. I wrote a dynamo script to aim creating filters from excel files, all things go well, but when I check the filter in Revit, the value in filter rule are all empty. Could you please help me to fix this. I just use the family template file system default metric.
Create filter_update.dyn (88.8 KB)
Test Filter 2.xlsx (8.5 KB)
You’ll need to show a screenshot of your graph in action. Make sure the whole thing is visible, the node titles are legible, and all the node previews are pinned.
@Nick_Boyts Thanks for your reminder. Please see this attached for more details
I have the same problem but I can’t figure out the solution. Hope that I can find one here.
You’re zoomed out too far. Your nodes are illegible and you haven’t shown the node previews for most of the nodes. Try again using Export Workspace as Image.
@Nick_Boyts I tried to capture it again
