2D Area of TIN Volume Surface
I wanted to get the 2D area of TIN Volume surface. Currently with Camber package I’m able to create TIN Volume surface and get Cut and Fill volumes. Is there any node in dynamo to get the 2D area of TIN volume surface?
Thanks.
I am pretty sure the Arkance Systems Node Library has a node for Surface statistics.
Edit: After a check it seems to work with Tin Surfaces only, not with Volume Surfaces.
I used to do that by pasting volumesurface in a temporary surface and get the property 2D area. If pasting surface into surface is not available in nodes you could have a look into the Python script node, however that requires a bit more effort.
Thank you very much. I found out the node and could successfully get the required output. Also I ran a quick check and compared the 2D area which outputs from Surface statistics and from Civil 3D volumes dashboard. Both are same.
Hi,What node you use to extract the 2D Area? Thanks
you could also ‘extract objects’ from surface and just check the ‘boundary’ box to get the area from
Can be done with dynamo ?
yes, can be done with 3 nodes:
Trying to replicate. I receive the errors shown. Not sure why?
This is giving an error because you are using a volume surface node and it should be a surface node.
Yep. Should have seen that, my brain must have froze up. Thank you. Trying to pull in TIN Volume surface data
