Hello there,
Just noticed that in Revit 22 Dynamo had the option to change the curved connectors to polylines but that option is no longer available in newer versions of Revit/Dynamo:
Snip from Revit 22/Dynamo v2.12:
Snip from Revit 23/Dynamo v2.16:
Has this feature been removed? If so, is there a way to bring it back?
Thank you.
I think you’re talking about this feature that’s now in the Preferences panel.
I was referring to the feature that allows the change of the connector lines to be either polylines or curves…
Polylines:
Curves:
That’s what I get for skimming your question…
Yes, I believe that option was removed as it wasn’t super popular and often made things more confusing when sharing graphs. While the setting still remains in the Settings.XML (at least for 2.16) it doesn’t actually do anything. So even if you changed the property in the settings file it still wouldn’t change the connector type.
Yeah - this was removed as it had a massive performance hit, and mostly made graphs harder to use due to overlapping lines.
